MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
action=parse
(main | parse)
Parses content and returns parser output.
See the various prop-modules of action=query to get information from the current version of a page.
There are several ways to specify the text to parse:
  1. Specify a page or revision, using page, pageid, or oldid.
  2. Specify content explicitly, using text, title, revid, and contentmodel.
  3. Specify only a summary to parse. prop should be given an empty value.
Parameters:
title
Title of page the text belongs to. If omitted, contentmodel must be specified, and API will be used as the title.
text
Text to parse. Use title or contentmodel to control the content model.
revid
Revision ID, for {{REVISIONID}} and similar variables.
Type: integer
summary
Summary to parse.
page
Parse the content of this page. Cannot be used together with text and title.
pageid
Parse the content of this page. Overrides page.
Type: integer
redirects
If page or pageid is set to a redirect, resolve it.
Type: boolean (details)
oldid
Parse the content of this revision. Overrides page and pageid.
Type: integer
prop
Which pieces of information to get:
text
Gives the parsed text of the wikitext.
langlinks
Gives the language links in the parsed wikitext.
categories
Gives the categories in the parsed wikitext.
categorieshtml
Gives the HTML version of the categories.
links
Gives the internal links in the parsed wikitext.
templates
Gives the templates in the parsed wikitext.
images
Gives the images in the parsed wikitext.
externallinks
Gives the external links in the parsed wikitext.
sections
Gives the sections in the parsed wikitext.
revid
Adds the revision ID of the parsed page.
displaytitle
Adds the title of the parsed wikitext.
headhtml
Gives parsed doctype, opening <html>, <head> element and opening <body> of the page.
modules
Gives the ResourceLoader modules used on the page. To load, use mw.loader.using(). Either jsconfigvars or encodedjsconfigvars must be requested jointly with modules.
jsconfigvars
Gives the JavaScript configuration variables specific to the page. To apply, use mw.config.set().
encodedjsconfigvars
Gives the JavaScript configuration variables specific to the page as a JSON string.
indicators
Gives the HTML of page status indicators used on the page.
iwlinks
Gives interwiki links in the parsed wikitext.
wikitext
Gives the original wikitext that was parsed.
properties
Gives various properties defined in the parsed wikitext.
limitreportdata
Gives the limit report in a structured way. Gives no data, when disablelimitreport is set.
limitreporthtml
Gives the HTML version of the limit report. Gives no data, when disablelimitreport is set.
parsetree
The XML parse tree of revision content (requires content model wikitext)
parsewarnings
Gives the warnings that occurred while parsing content.
headitems
Deprecated. Gives items to put in the <head> of the page.
Values (separate with | or alternative): categories, categorieshtml, displaytitle, encodedjsconfigvars, externallinks, headhtml, images, indicators, iwlinks, jsconfigvars, langlinks, limitreportdata, limitreporthtml, links, modules, parsetree, parsewarnings, properties, revid, sections, templates, text, wikitext, headitems
Default: text|langlinks|categories|links|templates|images|externallinks|sections|revid|displaytitle|iwlinks|properties|parsewarnings
wrapoutputclass
CSS class to use to wrap the parser output.
Default: mw-parser-output
pst
Do a pre-save transform on the input before parsing it. Only valid when used with text.
onlypst
Do a pre-save transform (PST) on the input, but don't parse it. Returns the same wikitext, after a PST has been applied. Only valid when used with text.
effectivelanglinks
Deprecated.
Includes language links supplied by extensions (for use with prop=langlinks).
section
Only parse the content of this section number.
When new, parse text and sectiontitle as if adding a new section to the page.
new is allowed only when specifying text.
sectiontitle
New section title when section is new.
Unlike page editing, this does not fall back to summary when omitted or empty.
disablepp
Deprecated.
Use disablelimitreport instead.
disablelimitreport
Omit the limit report ("NewPP limit report") from the parser output.
disableeditsection
Omit edit section links from the parser output.
disablestylededuplication
Do not deduplicate inline stylesheets in the parser output.
generatexml
Deprecated.
Generate XML parse tree (requires content model wikitext; replaced by prop=parsetree).
preview
Parse in preview mode.
sectionpreview
Parse in section preview mode (enables preview mode too).
disabletoc
Omit table of contents in output.
useskin
Apply the selected skin to the parser output. May affect the following properties: langlinks, headitems, modules, jsconfigvars, indicators.
One of the following values: monobook, rosstech, timeless, vector
contentformat
Content serialization format used for the input text. Only valid when used with text.
One of the following values: application/json, text/css, text/javascript, text/plain, text/x-wiki
contentmodel
Content model of the input text. If omitted, title must be specified, and default will be the model of the specified title. Only valid when used with text.
One of the following values: css, javascript, json, text, wikitext
